Front Disc not biting
AlpineAce
Whats the deal here? almost new echo 24, the front brake just isn't grabbing. I tried bedding it in, cleaning it etc. I feel like the power is there, but the front brake just doesnt Bite quick enough.
Contemplating new pads, any reccomendations? and what Part#? (that can hopefully be had in the USA easily)
rear brake Hydro/rim, works fine.
It could possibly be the pads, best ones I’ve used are either EBC reds which are really powerful once bedded in or Trialtech. Just make sure you get the right shape to match what you have.
well a while ago, when I first got the bike, the rotors were barely used, I took the pads out and used automotive brake cleaner. I may have also used a lighter to try and burn anything off. really made no difference. later I did just spray some water on the rotors. that seemed to help for a minute, but eventually back to lack of bite.
The fact that water made the brake work again, yet it went crap after drying back up, also points to contamination unfortunately.
New pads and rotor is the only 100% proper fix from here. If you do go that route, would recommend Hope Trial Zone V2 rotor and either Jitsie or Trialtech pads.
