Any ideas what bike?
Dazmo33
Possibly a Because Simple: https://www.pinkbike.com/photo/6057876/
EDIT:  A Because Simple.
Wheelbase: 1000mm
Chainstay Length: 362mm
BB Rise: +65mm
Head Angle: 71.5 degrees
Centre of BB shell to top centre of head tube: 595mm
BB will be a 68mm shell, head tube just needs a standard headset, 116mm drop out spacing, so fairly standard in terms of getting replacement bits if you need to.  Only slight problem is it's hard to get hold of that style of bashplate these days as people switched to the newer style mount orientation.
The stem on that bike looks relatively low and short, but if your son isn't super tall (i.e. sub 5ft or so) then that shouldn't be a problem.  If he's taller than that it may be worth investing in a 150mm trials stem for it at some point as it'll make the bike ride a bit better.
