Brian Bleech Posted June 6, 2019 Report Share Posted June 6, 2019 I haven’t a clue about discs brake so. a) Magura MT Sport b) Shimano XT M8000 c) Shimano Zee M620 Anything else worth considering that is good value? The M6000/7000? Quote Link to comment Share on other sites More sharing options...
Matt24. Posted June 9, 2019 Report Share Posted June 9, 2019 I am currently running Deore-6000. Front 180 green ebc pads a rear 160 with red ebc pads on a 24”. Front is spot on rear lacks hold a little but bite is good - planning to buy a rear zee caliper and 180 disc then should be spot on. I used exact same setup on a 20” alias and for that they were great. I like the fact if I smash up a lever it’ll be 20 quid to replace. They feel very solid at bite point - not spongy at all. I have hit them on the ground / walls a few times and seem to have held up to and they are really easy to bleed and swap cables about if running through internal routing. Think if you have a mod deore m6000 is powerful enough but on a 24 a rear zee or 4 pot is needed. Quote Link to comment Share on other sites More sharing options...
marg26 Posted June 9, 2019 Report Share Posted June 9, 2019 I find with Zee & standard Zee pads on my 24" Console I have to consciously grab the rear a little harder than the front. But that might just be a beginner getting used to needing lots of brake on the rear. Question: Trialtech Sport or EBC red? Quote Link to comment Share on other sites More sharing options...
Matt24. Posted June 13, 2019 Report Share Posted June 13, 2019 I’m about to fit a set of XT’s in about a week with Trialtech so maybe able to let you know then. I have found ebc reds pretty good even on the single pot deore Quote Link to comment Share on other sites More sharing options...
