SaFteiNZz Posted March 7, 2019 Report Share Posted March 7, 2019 Hello fellows, I'm new to trials and I'm actually using hs33 as my rim brake (front and rear) for my jitsie varial 26". I was wondering if there's a better brake lever for the hs33 that gives more power doing less strength or anyone that is more comfortable giving same or better braking power, I've seen trial tech, jitsie, clean ones but I don't really know if they will be better, more comfortable or just worse in everything. So please share your wisdom with me so I can choose, what do/did you use in your rim brake? Regards! Quote Link to comment Share on other sites More sharing options...
cwtrials Posted March 8, 2019 Report Share Posted March 8, 2019 Which version of the HS33 are you using? Any of the aftermarket ones will be way better than the current HS33 levers. Currently I'm using the Trialtech levers and quite happy with them. The clean and Jitsie should also be good as well. Quote Link to comment Share on other sites More sharing options...
