seaine Posted November 9, 2018 Report Share Posted November 9, 2018 Anyone had a problem with these? The plastic sleeve around the slave Disney seem to fit but with out it will slip slowly. any ideas on a fix? Quote Link to comment Share on other sites More sharing options...
gage-mann Posted November 9, 2018 Report Share Posted November 9, 2018 Washerless clamps? You won’t be able to use the plastic sleeves that go around the slaves if so. if the clamps aren’t keeping the slaves from moving but are tightened enough then you probably need to file them as they may have stretched from being tightened a lot previously Quote Link to comment Share on other sites More sharing options...
seaine Posted November 9, 2018 Author Report Share Posted November 9, 2018 They are brand new clamps,I will give it a file and see sure.i did wrap a bit of electrical tape around to try and get the gap abit tighter but no good Quote Link to comment Share on other sites More sharing options...
Cap Posted November 9, 2018 Report Share Posted November 9, 2018 They are washerless clamps so you won't be able to fit the plastic cylinder washers in. Make sure the clamp surface and the slave cylinder are cleaned properly and use grease on the bolts and they should work fine and hold the brake without slipping. Hope this helps 2 Quote Link to comment Share on other sites More sharing options...
