James.Parr Posted October 4, 2018 Report Share Posted October 4, 2018 As title says really, before I continue I would like to add this frame is cracked and bent before I got excited with a drill haha. I have tried to drill where I think is not a stressful place for the frame. I drilled an initial hole of 3mm then changed it to 6mm. Following this I angled the drill the angle that the cable would be gong into and out of the frame based around looking at my own bike. You can see with the cable going through the seat clamp area was not idea however with other frames like Marino’s the seat clamp is on top so if you cut your post down it would still clear fine (however in this instance it worked out well as I was able to see and show what was happening). Has any body got any advice on what else could be done? I thought of heat treating the area to make it stronger. Has anyone got any ideas or has this been done before? Cheers for responses in advance Quote Link to comment Share on other sites More sharing options...
dk2 Posted October 5, 2018 Report Share Posted October 5, 2018 Looks cool.. 1 Quote Link to comment Share on other sites More sharing options...
