Naygee2103 Posted September 24, 2018 Report Share Posted September 24, 2018 Hello, have always wanted to get into trials since i was young.. but never had the money for it “ still don’t “ was just seeing if i could have any guidance at a bike I have seen if I should be intrested or stay away.. I know it’s veryyyy cheap but I’m 20 getting mugged off on £5.90 a hour.... yeah new job needed. thanks for any help Quote Link to comment Share on other sites More sharing options...
Swoofty Posted September 27, 2018 Report Share Posted September 27, 2018 Wrong forum :-( Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted September 27, 2018 Report Share Posted September 27, 2018 As Swoofty says this is bicycle trials but I used to have a 98 Beta mototrials and that looks good for the money. Top end's are nice and easy to sort out the top end on (probably 6 bolts, a circlip then you'll just need piston kit with rings and a new gasket and you should be good to go. If the bike's local to you see if you can see/hear it running and take someone along who knows something about engines or if possible trials bikes. Clutch bleed should be easy but there may be a reason it needs bled (leaking seals etc.) so worth asking a few questions... If you're mechanically minded and happy to get your hands a bit dirty then I dont think you can go far wrong provided it's a runner and the person you're buying it off hasn't either just knicked it or ragged it round a quarry and killed it. Quote Link to comment Share on other sites More sharing options...
