Echo TR disc brake question ??
DeersSlayer
On an Echo TR front disc brake slave, is the bolt that holds the brake pads a 3 mm hex?
Or is it a "special" bolt head? All the other Echo brake bolts appear to be hex, but this bolt head seems a little messed up.
Bike is a 24" comp style Mk5. Bought it from TartyBikes 18 months ago, never had the brakes apart. I've lost some brake holding power, seems like maybe the pads are a bit glazed. Was trying to remove the pads, but the bolt wont take a hex key. 2.5 is too small, 3 wont go in. Bike has seen very little use, never in rain.
9 hours ago, Swoofty said:
It's the same as the Hope retaining pin. 3mm sounds right, I'm not gonna run out to the garage and check right now, sorry.
Yes, already confirmed it is 3 mm. But the 3 mm hex tool in my set is a bit too big or poorly 'machined', won't fit. Other 3 mm tools fit fine.
