Herbertlemon102 Posted August 23, 2018 Report Share Posted August 23, 2018 (edited) One of my Coust pads snapped in two while riding, material separated completely from the backing, didn’t realise that it has no tabs, it’s just glued on. Would superglue do it? Edited August 23, 2018 by Herbertlemon102 Quote Link to comment Share on other sites More sharing options...
old boy chez Posted August 23, 2018 Report Share Posted August 23, 2018 Would a 2 part epoxi be strong enough to hold it I there ? Quote Link to comment Share on other sites More sharing options...
Herbertlemon102 Posted August 24, 2018 Author Report Share Posted August 24, 2018 Mr. Wong said something similar 1 Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted August 24, 2018 Report Share Posted August 24, 2018 A decade or so ago we all just used to use standard superglue (cyanoacrylate) when making our own pads. The lack of tabs on the rear means no real mechanical lock which is a bit of a shame, but unless you often drag brakes lots then the pads are usually being pushed harder into the backing when braking, so it's really only to hold the polyurethane in place when you're not pulling the lever. An epoxy would create a stronger bond of course, but will take a little more effort to clean up if you want to put new material in place once it's worn down. 1 Quote Link to comment Share on other sites More sharing options...
