Built a tool for installing fittings into brake hose
Target
I never liked the idea of installing rim brake fittings to the brake hose using a vise and a hammer. It would be so much easier to have something similar to the chain tool, that can press the fitting into the hose. Also, you don't always have vice and hammer with you :)
The are some tools on the market for installing disk brake fittings, but they don't seem to be compatible with magura rim brake fittings. I found only one tool for installing rim brake fittings, but it is designed for usage in workshops, therefore it is large and expensive.
So I decided to build the tool myself, and make it in a portable, pocket size, so I can put it with a bleed kit and a bottle of fluid, and have it with me just in case. Quite satisfied with the result, the tool works really nice.
Ogoca_SSQhg-Z2DhiKy1V-byL1I9kHX4IiwDryyA
ofOQmB3ec2BIA_jUAk7kQi8pMZ9-LRyNlTDIWB8v
Using it is pretty simple. At first, you put the fitting with the guide into the hose
kHYYph4jVLirVq0nduaKnIsg1HdY01ZFo6_OI4OU
ux28r16f6VjNcmD4vnN2Hkv0KeHo2REyIRcsib2S
Then, you install the hose with the guide into the tool
pW-xlpfLEs4v0d7i75lnINz1S9v1UDIWUsfyEtmg
And fix the hose in PU clamps of the tool using allen key
uFRnRU8o2-qqqNQcqu98FXhJxD785xRE1LCvlTpF
Now it's time to start pressing the fitting into the hose
c1XWhxB92RPgt_z_17df8mdrNL4vwgsxzEiMJJIk
The fitting goes into the hose really smooth, no extra efforts needed
5zo3sSUHZtnUJ8imSR03ewFZVmOfCxiEaw-INSo2
And it's done!
AcGOeBOiU3SB68YgUCa2t1THU9lMB9N_BLJHD407
  • Like 9
2 minutes ago, Luke Rainbird said:
Overengineered solution to a problem that doesn't really exist, but very nicely executed. Kudos ^_^
Have you ever torn the brake hose or broken the fitting while riding? I have, and a few times. One time it happened during competitions. I don't know how I managed to press the fitting using bare hands, a pedal and a lighter, but after that I decided to build this tool.
  • Like 3
On 14/08/2018 at 4:10 AM, Canardweb said:
That is a great idea! Where did you get these PU clamps? And what is that guide made from? Any guide to build that tool?
I made PU clamps of a piece of polyurethane, it was polyurethane for shoe repairing that I bought years ago for making brake pads.
The guide is made from alu tube and 1.8 mm spoke centered in the tube with grub screws.
I don't have any guide, but I can send you some drawings if you want.
  • Like 1
