ZENITH Posted June 4, 2018 Report Share Posted June 4, 2018 (edited) Has dis demon since spring, she replaced a 2013 GU. Feels and rides awsum. Obv the front wheel moves are heaven because of the agressive head angle (73.5). I had a disk brake on the GU (BB7), now with the maggies on the front I dont miss it at all. Lost the modulation obviously, but I had a lot of hard time with gap to fronts etc. The disk just couldn handle them, now its instant stop. All in all the best bike I ever owned, suitable geometry, superb brakes (love the trialtech levers, big up to dose guys) and good weight (8.4kg). Quick riding video with her: https://www.youtube.com/watch?v=iHhMLTQLohM Frame and Forks - Frame: Echo MK6 - Forks: Echo Urban Tapered Wheels - Front hub: Clean HS V1 with red Monty Alloy bolts - Rear hub: Echo TR with red Monty Alloy bolts - Front rim: Hashtagg - Rear rim: Hashtagg - Spokes: DT Revolution (1.5) on the front DT Competition (1.8) on the back, both with alloy nipples - Rim tape: Echo, white - Inner tube (front): Maxxis Ultralight with red alloy valve cap - Inner tube (rear): CST with red alloy valve cap - Front tyre: Try-all Shift, 26" x 2.0" - Rear tyre: Monty Pro Race, 26" x 2.5" Brakes - Front brake: Magura HS33, Coust pads, Magura hose, Echo TR clamps, Trialtech Sport Lite lever - Rear brake: Magura HS33, Coust pads, Trialtech hose, Echo TR clamps, Trialtech Sport Lite lever Drivetrain - Cranks: Hashtagg, 175 ISIS - Freewheel: Reborn 135.9, 18T - Chain: KMC K810 - Rear Sprocket: Bonz 15T - Pedals: Echo TR Caged - Bottom bracket: Echo Titanium with Monty Alloy red bolts - Bashring: Echo SL Steering - Headset: Echo SL - Stem: Clean, 145mm x 25° with red a2z alloy top cap - Grips: Trialtech foam - Handlebars: Hashtagg carbon Edited June 27, 2018 by ZENITH 4 Quote Link to comment Share on other sites More sharing options...
Herbertlemon102 Posted June 6, 2018 Report Share Posted June 6, 2018 Lovely, I’d like one myself Quote Link to comment Share on other sites More sharing options...
