15mm bolt through trialtech hub
Archie H
Is it possible to take a standard sealed disc front trialtech hub with the pinch bolts and 10mm axle and change out the bearings to suit a 15mm bolt through? If so which bearings do I need and will it require new cone spacer things? I saw the cheaper arcade on tarty had a 15mm trialtech so I wondered if it could be done as an aftermarket upgrade? Thanks! :rolleyes:
