Dave Anscombe Posted May 21, 2018 Report Share Posted May 21, 2018 (edited) Heres my problem ,One of the nipples on my rear wheel is virtually non existent ,Ive had to use pliers to true my wheel in the past and this has fcuked it Thought i could extract it via a flat blade screwdriver but theres to much of the spoke poking though for that to work ...Only option i have is to just cut the spoke out and replace it. Does anyone know what length spoke il need for an echo tr rim on a try all h hub ? Hoping tarty guys or the addict lot can assist pretty sure its a three cross two cross spoke pattern ''tarty build'' from a long time ago. that rim - https://www.trendcycles.ch/shop/shop/Rims_19inch_20inch/rim_ECHO_TR_19_inch_rear/en/2/537 This hub but with perfectly round flanges ''not weight weenied cut out bits'' https://www.google.co.uk/search?q=try+all+h+hub&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjBuuXa2ZbbAhUIesAKHRfGDjIQ_AUICygC&biw=1366&bih=658#imgrc=lle6aqtThwEBbM: Edited May 21, 2018 by Dave Anscombe Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted May 21, 2018 Author Report Share Posted May 21, 2018 photos added Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 21, 2018 Report Share Posted May 21, 2018 From the photos that's 3x both sides. Looks like you'd need 175mm spokes. 1 Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted May 21, 2018 Author Report Share Posted May 21, 2018 cheers mark you still working at tartybikes ? is there anyway you guys could make sure thats the right length pleas ,I dont want to order the wrong size cheers for the quick reply Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 21, 2018 Report Share Posted May 21, 2018 I'm not, no. I have a copy of their spoke calculator here on my laptop though so worked it out on that. Worked out at 174.7mm assuming I've got the right hub details posted in there. If you're ordering from them, just say in the Notes what hub and rim combo it is (the TR rim has only ever had one ERD AFAIK). You can reply to your Order Confirmation e-mail with those photos to help point them in the right direction too. Quote Link to comment Share on other sites More sharing options...
Dave Anscombe Posted May 21, 2018 Author Report Share Posted May 21, 2018 Ahhh thats handy I only need a couple of spokes and nipples not a set ,so tarty is not ideal .....thanks for your help mark really appreciate it Quote Link to comment Share on other sites More sharing options...
Mark W Posted May 21, 2018 Report Share Posted May 21, 2018 Fair enough. Can always give them a buzz if you're just after a couple, I know they've done random amounts of spokes before for people if they just need a few. 1 Quote Link to comment Share on other sites More sharing options...
