Shimano Crankset - Saints vs SLX vs ZEE
cwtrials
I'm setting up a trials bike without trials specific cranks for the first time since power pro cranks on my brisa, and honestly haven't really been paying attention to the MTB tech scene since it changes every 3.2 minutes.  Trading a frame for a rear hope hub for this setup.
Can anyone explain the different between Saint, SLX, and Zee cranks?  Obviously Zee is budget friendly, but is there much of a difference?  SLX is lighter, but not as strong?  I found a good deal on some SLX cranks with bottom bracket in a 22/32/40 combo, compatible with a 104 bcd bashring I have and was thinking of giving that a go.
Edited by cwtrials
The Zee won't fit as they don't have small chainring mounting options, neither do the modern Saints (you'd have to find an older set). The SLX are great cranks and unless you're hucking massive drops they'll be plenty strong enough.
I'd also recomment the Sram Eagle GX cranks...light, stiff and strong (cheap too) plus you can use the Inspired one piece bash and sprocket to neaten everything up.
  • Like 1
11 hours ago, Daviesdt said:
What bottom bracket do you run?
The one I was looking at buying comes with a BB70.
That is a bit helpful thanks!
Thanks for the opinion!  I do drops I consider big (8'), but I know that's not really huge compared to what you're doing lol.  I'll look into the SRAM cranks, thanks for the info!
  • 2 weeks later...
  • 2 weeks later...
Finally got my Marino in.  Sadly there is no way to make the SLX cranks clear the chainstays, even with axle spacers.  I had it made with a 73mm BB shell, so I can't really use BB spacers.  Ugh.  Looking into other options.  Anybody up to buy a brand new pair of SLX cranks with basguard? lol
