onza wanabe Posted September 15, 2017 Report Share Posted September 15, 2017 Hey all i have a question i have some hope trial zones front is amazing working fine but the pistons on the rear wont stay in no matter what i do there is always constant rub on the disc ive re bled i thought maybe over filled it nope so let some fluid out made it slightly better but still the pistons are coming out i need some help please Quote Link to comment Share on other sites More sharing options...
ogre Posted September 15, 2017 Report Share Posted September 15, 2017 service them, get new seals and lubricate those badboys check the piston (i think thats what it's called; bit that actually moves the pad) for any damage or burs. Quote Link to comment Share on other sites More sharing options...
onza wanabe Posted September 15, 2017 Author Report Share Posted September 15, 2017 i have no idea how to service a hope brake haha will look for a guide somewhere this is the first time ive really used dual disc's Quote Link to comment Share on other sites More sharing options...
onza wanabe Posted September 16, 2017 Author Report Share Posted September 16, 2017 I have surfed the web and found nothing to help me with hope trial zone caliper servicing can someone possibly link me something please Quote Link to comment Share on other sites More sharing options...
ogre Posted September 16, 2017 Report Share Posted September 16, 2017 any hope servicing guide will work, the only difference between the trials and xc brakes is the size of the pistons to acheive different ratios, so long as you find a guide with a similar lever you should be able to work everything else out easily enough. just make sure you order the right consumable parts so you can re-build it. Quote Link to comment Share on other sites More sharing options...
onza wanabe Posted September 16, 2017 Author Report Share Posted September 16, 2017 On 9/16/2017 at 8:42 AM, ogre said: any hope servicing guide will work, the only difference between the trials and xc brakes is the size of the pistons to acheive different ratios, so long as you find a guide with a similar lever you should be able to work everything else out easily enough. just make sure you order the right consumable parts so you can re-build it. Expand i looked around and cannot find anything with the same caliper and cannot find a guide or video of anyone taking a hope piston apart lol il carry on looking. Quote Link to comment Share on other sites More sharing options...
ogre Posted September 16, 2017 Report Share Posted September 16, 2017 https://steveukmtb.wordpress.com/hope-caliper-overhaul-minitrialsm4v2m6/ they're all the same brakes inside. only differences are aesthetic and some degree of extra tech on the lever blades... Quote Link to comment Share on other sites More sharing options...
