Remove sprocket to lace a wheel?
peter_t
I need to relace a 19" wheel for a mate but the sprocket won't budge. I've tried the chain in the vice trick and soaked it in oil overnight first but so far no luck.
Say i can't get it off will i manage to get the new spokes in with it still on? its hard to tell without trying but don't want to without being sure as there may be no going back!
Anyone done this before?
Cheers, Pete
Try harder ;)
Tyre on and inflated helps, as does getting a friend involved.  Give it a countdown and both try and give the wheel a hard twist at the same time.  You need to shock the bond between the two apart rather than just trying to overwhelm it by pulling harder.
  • Like 2
