Hope help
Alex ktm
Hey guys been away from trials for 5 years now getting back into it and need brakes for my mod. I've found a set of hopes I.s. 3 calipers I know my forks will take them but will the frame? Rockman austin v2 something keeps telling me frames were is5 mounts but I can't remember :( any help appreciated cheers guys.
Alex.
You mean caliper No 3 and No 5. The first is 180mm rotor on the front, 160 on the rear, the second is 160mm on the front and 140 on the rear.
Does the Rockman frame has a +20mm mount? If so, you'd need a 180mm rotor on the rear to go with your frame and caliper (no adaptor needed, only the 0.1mm shims to center the caliper).
  • Like 1
