Onza Comp Crank
duc748r
Hi all,
Have an Onza comp (2010 model) and not had much use out of it. I have damaged the r/h crank as the pedal wasn't tight enough and it has damaged the threads of the crank. Any ideas where I can buy a new one? Had a look on google but keeps coming up with polished ones, a wee bit blingy for my liking, also was gonna keep it standard as the L/H crank is ok
cheers
Grant
1 hour ago, Daviesdt said:
I thought Cranks only came in pairs....?  I might be wrong though.  Would look a bit weird having a blingy right hand crank and a bog standard left.....  You might have to replace both.
You can buy individual sided cranks, so assume they can be changed. I just don't fancy blingy at all haha
