Ónodi István Posted March 27, 2017 Report Share Posted March 27, 2017 (edited) I'm currently using a hope mono mini disc brake with hope saw rotor, tried enough brake pads to realise that there isn't one for trials. On a mod, 160 mil rotor. I'm stuck between Hope trial zone/tech3 trial zone, no idea about disc rotor, jitsie pads looks like the way to go, any other things to consider? Edited March 27, 2017 by Ónodi István Quote Link to comment Share on other sites More sharing options...
Kushagra Rastogi Posted March 27, 2017 Report Share Posted March 27, 2017 Upgrade to 203mm rotors for full power,and if you like hopes then go for tech one instead of mono otherwise magura is best for trials yet i think (according to durability and power) And do not forget to get hope or magura adapters while upgrading to big rotor size Quote Link to comment Share on other sites More sharing options...
Greetings Posted March 27, 2017 Report Share Posted March 27, 2017 3 hours ago, Ónodi István said: I'm currently using a hope mono mini disc brake with hope saw rotor, tried enough brake pads to realise that there isn't one for trials. On a mod, 160 mil rotor. I'm stuck between Hope trial zone/tech3 trial zone, no idea about disc rotor, jitsie pads looks like the way to go, any other things to consider? Upgrading to a Trial Zone is already going to be a considerable improvement and probably your best bet. Even more so when you install Trialtech or Jitsie pads. A cheaper but heavier alternative to the Hope is the MT5 but you'll need some aftermarket brake pads for it to perform on par with the Hope on stock pads. Definitely wouldn't go with a larger disc than 160mm on a mod. 1 Quote Link to comment Share on other sites More sharing options...
old boy chez Posted March 27, 2017 Report Share Posted March 27, 2017 A hope trials zone or a old Saint m810 . 203 will be over kill for a mod . Quote Link to comment Share on other sites More sharing options...
niconj Posted March 28, 2017 Report Share Posted March 28, 2017 Mt4 with Trialtech pads should do the trick as well. Quote Link to comment Share on other sites More sharing options...
ogre Posted March 28, 2017 Report Share Posted March 28, 2017 180 rotor on a mod is fine if your a big boy the new hope rotor with straight spokes seems pretty good, i've got one in 180 with jitsie pads and it's daft powerful 1 Quote Link to comment Share on other sites More sharing options...
