CC12345678910 Posted March 25, 2017 Report Share Posted March 25, 2017 I've had this headset for absolute time and the lower bearing has been stuffed for a fair while (far far too long infact) and I want both of them changed cos it really is about bloody time I sorted this. Question is, does my Neon Bow HS take 36/45 deg bearings or 45/45deg? ^ Description says Echo forks with the intergrated crown race fit, so I guess I need 45/45deg? Also If tarty lads read this, do you not stock replacements of have I missed them? I guess mabye that the Echo SL bearings fit and that might be the answer? Cheers peeps. Ciaran. Quote Link to comment Share on other sites More sharing options...
BJ. Posted March 25, 2017 Report Share Posted March 25, 2017 From the top of my head I'm pretty sure it's 45 x 45 if you're struggling sourcing them give me a message and I'll pop you some in the post they're £6 each plus postage. 1 Quote Link to comment Share on other sites More sharing options...
bing Posted March 26, 2017 Report Share Posted March 26, 2017 I got mine off Planet X website, about £4 each if I recall. They have both options as well Quote Link to comment Share on other sites More sharing options...
Greetings Posted March 26, 2017 Report Share Posted March 26, 2017 Unless something has changed, the Neon Bow headset uses 45/45 bearings so the ones from an Echo SL headset (and many many others) will fit. 1 Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted March 28, 2017 Author Report Share Posted March 28, 2017 On 3/26/2017 at 0:08 PM, Greetings said: Unless something has changed, the Neon Bow headset uses 45/45 bearings so the ones from an Echo SL headset (and many many others) will fit. When I say I've had my HS for absolute time, I mean since about early 2012, so you're probably right. @bing I check that out. @BJ. If my part sourcing skills crap out I'll take you up on that offer. Cheers to all of you though. Quote Link to comment Share on other sites More sharing options...
lifes-a-trial Posted March 28, 2017 Report Share Posted March 28, 2017 On 3/25/2017 at 8:08 PM, CC12345678910 said: Also If tarty lads read this, do you not stock replacements of have I missed them? I guess mabye that the Echo SL bearings fit and that might be the answer? Cheers peeps. Ciaran. Why don't you just get in touch with tarty instead of hoping they read your post ? I am sure that they will sort you out . Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted March 30, 2017 Author Report Share Posted March 30, 2017 On 3/29/2017 at 0:58 AM, lifes-a-trial said: Why don't you just get in touch with tarty instead of hoping they read your post ? I am sure that they will sort you out . The same reason I didn't tag any of them in my original post. Because I may not use them if I source bearings from er, other sources, as I ihave always intended to do, I feel that directly messaging a supplier for their info and then not making the final purchase with that supplier is a dick move. Quote Link to comment Share on other sites More sharing options...
