26" Rim Problem
Julius Czar
Hi all.
Decided to take my friends front wheel apart to replace the nipples, as it was horribly buckled and I had no way of truing it.
I've pulled the wheel apart and the rim itself has remained buckled. Is there any way of getting it a bit straighter prior to rebuilding? Or is there a technique for building the buckle out as such?
Thanks.
On 12/03/2017 at 8:01 PM, craigjames said:
How badly buckled is it? If it's as bent as it sounds then you'll struggle to pull it true and round again.
It's bad enough that you can see it without spinning it if you know what I mean, it's fairly Pringled as such.
I was just curious as to whether there was a "go to" method as such for straightening them out or if my best bet was to just hammer it :P
I'll have a go at bashing it back straight, if not it'll have to be a new rim.
cheers guys!
