Scott Gibbs Posted February 24, 2017 Report Share Posted February 24, 2017 I'm looking for some feedback/opinions on a frames rear disc mount. I've seen over the years a massive change in the design of frames to accommodate rear discs. I've got a 24UK and like most riders I want to run a rear disc. that is the rear disc mount on my frame is something like an MT6 with a 180mm rotor going to destroy my frame or would it be ok? Bearing in mind I'm not a big hit kind of a rider. Or is a HS33/V brake my only option? Quote Link to comment Share on other sites More sharing options...
Mark W Posted February 24, 2017 Report Share Posted February 24, 2017 With the lack of reinforcement, the really short mount and it all ending at the end of the chainstay like that I think it wouldn't do a great job at dissipating the stress you're putting through it. It might be work, but most frames I've seen like that haven't last all that long. If you want to go for longevity it might worth sticking with a rim brake. Quote Link to comment Share on other sites More sharing options...
LEON Posted February 24, 2017 Report Share Posted February 24, 2017 I've seen worse. 1 Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted February 24, 2017 Author Report Share Posted February 24, 2017 So basically I'm screwed! Quote Link to comment Share on other sites More sharing options...
LEON Posted February 24, 2017 Report Share Posted February 24, 2017 Well I wouldn't put a 205 Saint on it. If you've got rim brake mounts too at least you've got a backup. From your riding and brake description you might be alright for a little while, but the rim brake will be the long term solution. Quote Link to comment Share on other sites More sharing options...
Scott Gibbs Posted February 24, 2017 Author Report Share Posted February 24, 2017 (edited) Maybe better keeping this one in the loft for classic status and buy a steel frame instead. Edited February 24, 2017 by Scott Gibbs Quote Link to comment Share on other sites More sharing options...
