Bottleneck Posted December 2, 2016 Report Share Posted December 2, 2016 Hi guys, i seem to have a problem with hydraulic disc brakes. All of the ones I've had have started leaking at the master cylinder after only a few months of use! I've had a few Echo tr's, Hope and Hayes, and always ended up with the same problem. I don't suppose it's normal? Any suggestions? I'm feeling sort of hopeless (pun intended)... Thanks! Quote Link to comment Share on other sites More sharing options...
niconj Posted December 2, 2016 Report Share Posted December 2, 2016 (edited) Trialzone, Saint, MT6/7 are all very good brakes that don't leak. If for some reason all the brakes mentioned start to leak on your bike, go for an Avid BB7 with Trialtech pads. In my opinion this brake (good cables and SD7 levers) are well up there with the hydraulic counterparts. If it starts leaking as well, you might have some very bad karma. Edited December 2, 2016 by niconj 1 Quote Link to comment Share on other sites More sharing options...
Mikee Posted December 2, 2016 Report Share Posted December 2, 2016 Have they been second hand or new brakes? Are you rebleeding them yourself or having them rebled before the leaking occurs? Quote Link to comment Share on other sites More sharing options...
Bottleneck Posted December 3, 2016 Author Report Share Posted December 3, 2016 On December 2, 2016 at 1:52 PM, Mikee said: Have they been second hand or new brakes? Are you rebleeding them yourself or having them rebled before the leaking occurs? These were all new brakes from Tarty, except for the Hayes. They started leaking before any rebleeding, and bleeding them again didn't seem to help On December 2, 2016 at 11:39 AM, niconj said: Trialzone, Saint, MT6/7 are all very good brakes that don't leak. If for some reason all the brakes mentioned start to leak on your bike, go for an Avid BB7 with Trialtech pads. In my opinion this brake (good cables and SD7 levers) are well up there with the hydraulic counterparts. If it starts leaking as well, you might have some very bad karma. I did think about going for cable brakes, these certainly won't leak! Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted December 3, 2016 Report Share Posted December 3, 2016 Not being funny, but something's clearly not right if all those brakes are leaking you but with nobody else having the same issue. I assume you've contacted Tarty about any warranty-worthy issues? If it's not down to that, then perhaps it's not the product that's at fault and some other issue needs putting right. 1 Quote Link to comment Share on other sites More sharing options...
Paperclip Posted December 3, 2016 Report Share Posted December 3, 2016 What part of the lever leaked on the Hope? You don't store your bike upside down for a period of time do you? Quote Link to comment Share on other sites More sharing options...
Bottleneck Posted December 3, 2016 Author Report Share Posted December 3, 2016 Wait... I feel so stupid right now, but I actually meant that the brakes were leaking at the callipers. Got my vocabulary mixed up... Apologies Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted December 3, 2016 Report Share Posted December 3, 2016 Where abouts; Where the hose joins the caliper or around the pistons/join if 2-piece? Quote Link to comment Share on other sites More sharing options...
niconj Posted December 3, 2016 Report Share Posted December 3, 2016 Just get BB7s and be happy. 1 Quote Link to comment Share on other sites More sharing options...
Bottleneck Posted December 4, 2016 Author Report Share Posted December 4, 2016 It leaks around the pistons, so the oil gets onto the pads and the brakes basically stop working (no surprise) Quote Link to comment Share on other sites More sharing options...
LEON Posted December 4, 2016 Report Share Posted December 4, 2016 I've had saints leak from there, you don't lube the pistons or anything do you? Quote Link to comment Share on other sites More sharing options...
Daviesdt Posted December 10, 2016 Report Share Posted December 10, 2016 @Bottleneck callipers leaked all over my pads and rotors from my echo tr's, hadn't seen that much use either when they went, may have been a bunch of faulty seals have been in circulation from the factory, thankfully the guys at tarty bikes helped put things right for me, not had any problems since. Sounds like you are having some bad luck if all your brakes are going. Just get some new seals put on the ones you have now and swap your pads and rotors, not much else you can do cept grin and bear it..... Quote Link to comment Share on other sites More sharing options...
