urgent help broke my fork
signo97
2 hours ago, Luke Rainbird said:
It's possible to take a smidge off the dropout (or the hub) if needs be, though not the perfect solution.
Works though. I did this with a Trialtech Fork and an Echo Hub. I'd rather file down the axle than the fork though.
Do this.
I had to file two flats in each side of my because hub's axle (very similar to an echo TR hub) in order for it to fit my element fork's dropouts. That was getting on for 5 years ago. You may wish to carefully file away the paint from inside the dropouts of your element forks, but stop filing when you see metal.
Edited by CC12345678910
