Slowro Posted November 13, 2016 Report Share Posted November 13, 2016 I am going to switch to a full disc setup soon, I have yellow pads on my hs33's no idea what they are but does anyone have a recommendation for wet muddy conditions. As for the tyres I have a moto digger rear that's ok just wondering if there's better for winter Quote Link to comment Share on other sites More sharing options...
niconj Posted November 13, 2016 Report Share Posted November 13, 2016 Tnn ADM + Continental Air King/Maxxis Swampthing ST/Maxxis High Roller ST 1 Quote Link to comment Share on other sites More sharing options...
BJ. Posted November 13, 2016 Report Share Posted November 13, 2016 French Coust Pads or TriLite CNC backed green pads. Maxxis Swampthing super tacky if you can get hold of one. If not probably a Schwalbe Fat Albert Quote Link to comment Share on other sites More sharing options...
RossBurnside Posted November 14, 2016 Report Share Posted November 14, 2016 15 hours ago, BJ. said: French Coust Pads or TriLite CNC backed green pads. Maxxis Swampthing super tacky if you can get hold of one. If not probably a Schwalbe Fat Albert Only problem with the Schwalbe compound is it's a bit plasticky - I'd defo try get hold of a Swampthing or if not a Highroller? Just make sure you get the 40a compound, although again that's easier said than done:/ Quote Link to comment Share on other sites More sharing options...
SamKidney Posted November 14, 2016 Report Share Posted November 14, 2016 Schwalbes are awful for trials. Plasticky is the perfect word to describe them! Definitely not a winter tyre, I had more faith in my Holly Roller when I ran that on the rear briefly. Id definitely try hunt down a Swampthing or High Roller. My 40a High Roller had next to no tread left and still gripped like shit to a blanket in the wet. Rode Shipley Glen in all weathers and it was predictable which instilled confidence. Pad wise, I've never been able to fault TNN ADM's. Again, rode wet weather natural with lots of mud, grass, grit etc.. any pad is going to suffer in those circumstances but I knew what the brake would and wouldnt do. Just ride within the limits. The 40A compound really is good. It was actually better as a near slick tyre as it never picked up any mud so always gave brilliant tyre to ground contact. 1 Quote Link to comment Share on other sites More sharing options...
Alex Dark Posted November 15, 2016 Report Share Posted November 15, 2016 Conti Air King ----- Coust pads Quote Link to comment Share on other sites More sharing options...
niconj Posted November 15, 2016 Report Share Posted November 15, 2016 9 hours ago, Alex Dark said: Conti Air King ----- Coust pads Depending on the rim the ADM are better. Quote Link to comment Share on other sites More sharing options...
craigjames Posted November 15, 2016 Report Share Posted November 15, 2016 16 minutes ago, niconj said: Depending on the rim the ADM are better. In your opinion. I've found Cousts just seem to work, no matter the rim or the conditions. But that's just my experience. Quote Link to comment Share on other sites More sharing options...
niconj Posted November 15, 2016 Report Share Posted November 15, 2016 17 minutes ago, craigjames said: In your opinion. I've found Cousts just seem to work, no matter the rim or the conditions. But that's just my experience. They didn't work on Trialtech SL rims but then again, no pad did. Quote Link to comment Share on other sites More sharing options...
Paperclip Posted November 15, 2016 Report Share Posted November 15, 2016 2 hours ago, niconj said: They didn't work on Trialtech SL rims but then again, no pad did. Rockman blue in cnc worked so good on this rim for me with a medium grind when I ran a Magura. Quote Link to comment Share on other sites More sharing options...
Slowro Posted November 17, 2016 Author Report Share Posted November 17, 2016 Thanks for the suggestions guys, I'm starting back at square one after a long long long time away. i keep thinking I should have bought a 26" but I'm having fun anyway Quote Link to comment Share on other sites More sharing options...
niconj Posted November 17, 2016 Report Share Posted November 17, 2016 13 minutes ago, Slowro said: Thanks for the suggestions guys, I'm starting back at square one after a long long long time away. i keep thinking I should have bought a 26" but I'm having fun anyway Began with a 24'' Marino street, went over to various 24'' pure trials, got a 26'' pure trial and now am back to a 24'' Inspired street trial. 1 Quote Link to comment Share on other sites More sharing options...
weebryan Posted November 18, 2016 Report Share Posted November 18, 2016 Pretty happy with my swampthing and just started using adm and was using beegreens just to see if and better Quote Link to comment Share on other sites More sharing options...
RossBurnside Posted November 18, 2016 Report Share Posted November 18, 2016 On 11/14/2016 at 8:20 PM, SamKidney said: Schwalbes are awful for trials. Plasticky is the perfect word to describe them! Definitely not a winter tyre, I had more faith in my Holly Roller when I ran that on the rear briefly. Id definitely try hunt down a Swampthing or High Roller. My 40a High Roller had next to no tread left and still gripped like shit to a blanket in the wet. Rode Shipley Glen in all weathers and it was predictable which instilled confidence. Pad wise, I've never been able to fault TNN ADM's. Again, rode wet weather natural with lots of mud, grass, grit etc.. any pad is going to suffer in those circumstances but I knew what the brake would and wouldnt do. Just ride within the limits. The 40A compound really is good. It was actually better as a near slick tyre as it never picked up any mud so always gave brilliant tyre to ground contact. Exactly my set up hahahahaha TNNs and a highroller Quote Link to comment Share on other sites More sharing options...
