cleep2 Posted October 7, 2016 Report Share Posted October 7, 2016 Is it possible to run a magura mt7 calliper with a normal magura brake lever? Quote Link to comment Share on other sites More sharing options...
JJ Leigh Posted October 7, 2016 Report Share Posted October 7, 2016 depends on the lever i guess but more than likely i'd say yes Quote Link to comment Share on other sites More sharing options...
Dman Posted October 7, 2016 Report Share Posted October 7, 2016 Clarify normal, if you mean rim brake id say no. Also shimano levers have been tried with the magura calipers but didn't work right so im told. Quote Link to comment Share on other sites More sharing options...
niconj Posted October 8, 2016 Report Share Posted October 8, 2016 9 hours ago, Dman said: Also shimano levers have been tried with the magura calipers but didn't work right so im told. How come? Many MTB riders swapped the MT5/7 levers with Shimano 810/820 levers and couldn't be happier. @Martin Direske did this as well. Quote Link to comment Share on other sites More sharing options...
Dman Posted October 8, 2016 Report Share Posted October 8, 2016 1 hour ago, niconj said: How come? Many MTB riders swapped the MT5/7 levers with Shimano 810/820 levers and couldn't be happier. @Martin Direske did this as well. @Mark W Said he tried? Quote Link to comment Share on other sites More sharing options...
niconj Posted October 8, 2016 Report Share Posted October 8, 2016 I'll put some 810 or 665 levers on there as soon as possible. The Magura ones are horrible. Quote Link to comment Share on other sites More sharing options...
cleep2 Posted October 8, 2016 Author Report Share Posted October 8, 2016 I basically want to run a Hashtagg lever or trialtech lever with the magura caliper Quote Link to comment Share on other sites More sharing options...
niconj Posted October 8, 2016 Report Share Posted October 8, 2016 34 minutes ago, cleep2 said: I basically want to run a Hashtagg lever or trialtech lever with the magura caliper Won't work properly. Hashtagg has a 14mm piston the Magura Mt levers 10mm. Quote Link to comment Share on other sites More sharing options...
Jack Heard Posted October 9, 2016 Report Share Posted October 9, 2016 On mine I'm running an mt7 calliper with an mt6 lever. It works perfectly Quote Link to comment Share on other sites More sharing options...
Ali C Posted October 9, 2016 Report Share Posted October 9, 2016 they're the same lever Quote Link to comment Share on other sites More sharing options...
