Crank help
Jack Heard
Hi guys, buying the new arcade frame and I really don't want to run the arcade crank. The only problem is I don't have a clue about cranks. Can anybody help me find a crankset? Needs to be light and a 22t also I have no idea how they fit together or what parts I need
Id get the race face turbines, the standard ones like ali runs would be stronger or the cinch ones like i have.
Im biased but they look better than the others and if ali bends shimanos and race face are fine with him, they will last us.
Do you want 170 or 175 length arms?
You need cranks with a dual spider, one set of bolt holes for your 22t chainring in 64 bcd, bolt circle diameter and the other holes at 104bcd.
You would also want a 68/73 bb, to suit whatever crank spindle size you get.
For my crankset you would need.
http://www.chainreactioncycles.com/mobile/race-face-cinch-30mm-series-bottom-bracket/rp-prod113372
BB in bsa 68/73
http://www.chainreactioncycles.com/mobile/race-face-cinch-direct-mount-crankset-spider/rp-prod113259
Double 104 bcd
http://www.chainreactioncycles.com/mobile/race-face-turbine-cinch-direct-mount-crank-arms/rp-prod125720
Cranks in 170 or 175
You would also need a 64 bcd 22 tooth chainring. I use middleburn.
And a 104 bcd bashring and bash bolts.
@Jack Heard
I just remembered you will need the race face bb spanner for that bb.
http://www.chainreactioncycles.com/mobile/race-face-bsa-bottom-bracket-installation-tool/rp-prod144688
And a 16mm hex key to install cranks.
And a shimano isis style bb tool to install the cinch spider.
http://www.chainreactioncycles.com/mobile/x-tools-bb-tool-isis-socket-fitting/rp-prod10177
So its expensive.
Edited by Dman
Yes but only by landing on it and breaking it, and it wasnt in stock anywhere, its a small plastic ring it costs about £16 if you do break it, its all been fine since i refitted it all properly. If your concerned get the non cinch turbine crankset, less to go wrong.
  • Like 1
