ooo Posted September 5, 2016 Report Share Posted September 5, 2016 I find that my TNN ADM's stop working when it gets really cold. Would using a pad with a softer compound work better for the cold ? Cheers Quote Link to comment Share on other sites More sharing options...
Bottleneck Posted September 5, 2016 Report Share Posted September 5, 2016 I used TNN LGM and Heatsink Yellows last winter at -30 centigrade. The brakes were working better than my fingers, that's for sure! 1 Quote Link to comment Share on other sites More sharing options...
cwtrials Posted September 5, 2016 Report Share Posted September 5, 2016 My cousts worked ok in the cold. Generally speaking all pads will not work as well when temperature drops below freezing. Quote Link to comment Share on other sites More sharing options...
Tony Harrison Posted September 5, 2016 Report Share Posted September 5, 2016 I've always found the Magura red ones work fine. Quote Link to comment Share on other sites More sharing options...
lifes-a-trial Posted September 5, 2016 Report Share Posted September 5, 2016 Magura cold stop heated pads . batteries not supplied. 1 Quote Link to comment Share on other sites More sharing options...
ooo Posted September 7, 2016 Author Report Share Posted September 7, 2016 On 9/5/2016 at 11:15 AM, Bottleneck said: I used TNN LGM and Heatsink Yellows last winter at -30 centigrade. The brakes were working better than my fingers, that's for sure! Did you use LGm on rear and yellows on front ? or both pads on rear at separate times? On 9/5/2016 at 2:14 PM, cwtrials said: My cousts worked ok in the cold. Generally speaking all pads will not work as well when temperature drops below freezing. So did cousts work better than other pads you tried or do you mainly use cousts ? Also do you have any idea how hard these are compared to other pads ? Quote Link to comment Share on other sites More sharing options...
SamKidney Posted September 7, 2016 Report Share Posted September 7, 2016 Strange one, my ADMs worked brilliantly in winter. LGMs are a good all weather pad Quote Link to comment Share on other sites More sharing options...
Bottleneck Posted September 8, 2016 Report Share Posted September 8, 2016 Actually I used the yellows on rear and LGM's up front on a stock and LGM's at the rear on a mod. I guess I should add that they use this nasty road salt thingie in Moscow which renders any pads pretty much useless... but when I avoided letting this stuff touch the rims, the brakes were good enough. Quote Link to comment Share on other sites More sharing options...
DK. Posted September 17, 2016 Report Share Posted September 17, 2016 Coustpads are just the best pads for everything. Although PhatPads were superior in my opinion - R.I.P Phatpads!! Quote Link to comment Share on other sites More sharing options...
craigjames Posted September 17, 2016 Report Share Posted September 17, 2016 Coustpads are pretty damn good in all conditions, as were Koxx (TK) browns and reds. Gonna have to disagree with Danny about Phatpads though, most inconsistent pile of poop you could put in a HS33. But each to their own. Quote Link to comment Share on other sites More sharing options...
