switching heatsink yellows to magura plastic backings
jeff costello
i've had problems with the alignment of my hs33 back brake since yesterday. today i noticed that one plastic backing of my heatsink yellows broke. clean in the middle, into two pieces.  i'm going to order alu backings as soon as possible, but this will take at least a week and i want to be able to ride my bike in the meantime.
so, i have a pair of old magura pads (black ones, plastic backings as well). should i
# try to pry the magura rubbers out (heat up in the oven first?) and put the heatsink rubbers into the magura backings?
# just run the magura pads as they are until the new backings arrive?
i'm asking you first, because i don't want to ruin the magura pads as well and then be left with no pads at all. can post pics if needed. thanks.
Edited by jeff costello
I think they should superglue in fine the backings look identical, the only thing is the black standard magura pads are very soft so heat them up well and don't pull on them very hard or they will tear.
