V-brake set ups
Scott Gibbs
5 hours ago, ItsMatt said:
some of the germans seem to be running silky smooth Vee setups if I remember correctly.
@insomnia
It's @Martin Direske who's been running Vees for ages. He has old style SD7 levers and Ultimate brakes if I remember correctly (with a Shimano Carbone booster). I run SD7 levers and Ultimate brakes with Oddyssey linear slick cables. My brake (on a Rockman Gabbro with Vee mounts and a cheap Tektro booster) is super quiet but as powerful as a well setup HS33; the hold is even better. The force required to pull the lever is as little as a water bled HS33. The only thing is that the bite point is a bit mushy due to the cables.
  • Like 1
Well after somehow ripping my Avid SD7 arm apart, when i was setting it up cause i'm a ham fisted bad jock, i went to Evans in desperate times and bought some cheapy Shimano Alvio's.
I'm really impressed so far, couldn't be happier.
Edited by Davetrials
