adamant Posted July 14, 2016 Report Share Posted July 14, 2016 I'm thinking about selling my czar mod as it never gets used anymore spec: czar mod frame monty forks(not pictured) echo headset onza stem unknown riser bars echo front hub on try-all rim with kenda small block 8 tyre monty cranks with metal pedals, rockman freewheel, try-all bb, tensile bashring onza rear hub with Monty rim drilled out, with maxxis creepy crawler hydraulic shimano front disk brake with 180mm disk avid sd7 lever with slic cable, shimano arms, echo booster, heatsink cnc yellow pads, onza brake adaptors Quote Link to comment Share on other sites More sharing options...
Tom2015 Posted July 14, 2016 Report Share Posted July 14, 2016 200-250 Quote Link to comment Share on other sites More sharing options...
