marcel-ahrens@live.de Posted April 12, 2016 Report Share Posted April 12, 2016 Hi together, has Anybody on a 26" Bike 165 mm cranks ? For example on a Crewkerz ? If yes what is The Different is it easier to Stay on backwheel Maybe in Pedal up ? And better for Sidehop and other technics ? please help lg Quote Link to comment Share on other sites More sharing options...
Luke Rainbird Posted April 12, 2016 Report Share Posted April 12, 2016 If you have short legs, shorter cranks can help stop you feeling like you're spinning wildly. If you can't quite get a nice-feeling leverage ratio once running a gear ratio you like, then tweaking crank lengths can help. If you often find you don't have the ground clearance you need, shorter cranks will help slightly. There's not really a huge difference in terms of it actually making certain techniques easier (in fact, the extra leverage of longer cranks will give you more "power" at the cost of moving your feet negligibly quicker). Quote Link to comment Share on other sites More sharing options...
marcel-ahrens@live.de Posted April 12, 2016 Author Report Share Posted April 12, 2016 Hi mate, thanks for your answer, i Write you in Facebook a Message . You think more power is on longer cranks yeah ? My legs Are not so Short i think. My Size is 1,78 Meter Quote Link to comment Share on other sites More sharing options...
cleep2 Posted April 14, 2016 Report Share Posted April 14, 2016 I know that jack Carthy and other leading riders use 165mm cranks, apparently it makes the pedals stroke faster therefore more responsive and better on technical Quote Link to comment Share on other sites More sharing options...
JKH Posted April 14, 2016 Report Share Posted April 14, 2016 The biggest difference with 165mm cranks is that your cranks/pedal/foot will not hit on things like the ground (for comp bikes), and your your foot will not rub the front tire (for street bikes). Sure, in theory longer cranks have less leverage, but I don't think many top riders are lacking in the leg strength department. Quote Link to comment Share on other sites More sharing options...
