Magura HS33 11 leaking?
euljeune
Took the lever apart again today to clean it, I did replaced the piston for a racing line one some time ago and I've always use magura oil in these so far, finished by a bleed that felt solid but I kept having to screw in the adjustment during a riding session. So Im loosing oil somehow, I think it's from the lever: I inserted a piece of tissue in the lever around the link to check and it got blue wet after riding a bit.
Are the 2011 HS33 known to be leaky? Could the master cylinder have wear out? Any comments appreciated.
Thanks Adam, I did not recall seeing any major scratches but will check again. But even though I have the aluminium piston it should not really be in contact with the cylinder, the o-rings are no?
Are the new 2013 hs33 made of this plastic composite material again?
