FFW on the rear of a Street trial?
niconj
Sorry if this question has been posted before, I can't find anything related.
I'm in the process of building up an Onza Zoot Pro for which I've got a new frameset pretty cheap. Now I don't want to spent too much money on it and as I still have a fixed rear disc hub and a FFW, I was thinking of putting these things together.
Would I get problems with the chain line? If not, what gear ratio is recommendable (FFW is 18T)?
Thanks.
True... oh my gosh... haven't thought about this. Still the chain line could be a problem as I need to put in a BB and I don't know if 128mm is too much.
What about the gear ratio? 18:14 too small probably.
Edited by niconj
If you're using an 18t freewheel on the rear you'd need to size up to around 23t up front.  Stan's using that setup on his Fourplay and it works fine.  Otherwise, you'd be needing a 16t freewheel with a 22t sprocket/chainring up front which would boost the cost a bit.
If you're running 175mm cranks, I'd go 18:13.  18:14 felt too light to me when I ran it and I seem to remember you were wanting harder gearing on your 26" bike too?
Not necessarily but it seems like a good plan. There's plenty of power in my legs with no technique whatsoever. :D
Still indecisive as to build up a Street Trials or a Mod.
Edited by niconj
