Hope trials rear brake (disc).
josh of super Leeds
Right lads I have a problem with the new Hope Trial Zone rear brake. First of all it seam's to have a lot of travel before any sort of bite. Then the pads slip under minor stress which to say the least I am 11 and only six stone. Now we first tried burping the lever and got a short time result and then so totally re-bled the whole system. Yep the lever feels better but still some slip. Now one of the Tyke lads said go Jitsie pads cos they are better than Hope? I don't know how he knows this as he has only ever being on rim brakes?
Please give me help it's a Hope trial zone on a 2015 Monty 221k pro.
For it to be slipping for someone your size, it's probably one of two things.
Either your pads and/or rotor are contaminated with a bit of oil/grease which is where I'd just buy new ones, but you can clean them if you're persistent.
The other option is that you're not pulling the brake hard enough ;)
  • Like 1
