200/203 rotor on 2012 4play, will I die?
isitafox
Seeing as the search currently doesn't pick up anything before the forum upgrade I'm having to ask this question again. 200/203 rear brake on a 2012 4play frame, I know they go out of warranty above 180mm but has anyone actually killed one running a 200/203??
Please, just please don't use an adaptor that you can bend with your hands, I'm running out of smug faces.
If it's as thick as one of these below then you deserve all the broken calipers in the world. Let's have a safe 2016 with no wasted calipers.
  • Like 1
