Are HS33 Slave Cylinders Serviceable?
reece91
Hey guys,
My 05 HS33 slave cylinders have a slight weep coming from the piston, I had quick look at Tarty and couldn't see anything to do with spares for slave cylinders besides the olive.
So are the slave cylinders serviceable? And does anyone has any parts diagrams that I can refer to?
You can't take them apart.  Sometimes cleaning them out real well and adding some silicon lube around the piston will help.  If it's coming from one of the fittings you may just need to redo the fitting.
But, if its shot get a new cylinder.  There's a good chance somebody local has one sitting in a parts bin they would give you.
