Magura 2011-2014 bar clamp bolt with allen?
ooo
Although the standard bolts are a really coarse thread, if you look inside the lever it looks like it's been threaded to accept both that type of bolt and also a more fine pitch bolt too.  @AndyT managed to fit some fairly 'normal' bolts to his that I believe had a regular allen key broaching on them that used a completely different thread from standard, but seemed to work.
  • Like 1
Yeah I just slammed a tiny bit bigger bolt in, went slow- it held real tight. The material is like Parmesan cheese but a little tighter, if you get a tiny bit bigger bolt you'll be ok. Only rode with it for a month as a riding buddy gave me an 05 lever so I went to that..prefer the feeling of the lever.
good luck !
