SLX Cranks and bash
Jay T
I think Ali bought a cheap solid BMX chainring then cut that up to suit.  You basically just need a disc of material that you can put a ~34mm hole in the middle of.  The shape of the bash will depend on the frame you're running as you just need to cut a notch out of it to allow your chainstay to pass through.
