Crewkerz Cleep 2
Canardweb
Here is my new bike. It's a Crewkerz Cleep 2 size L. I am still getting used to it, but I wanted to share it with you. I want to thank Christian Gugliotta very much as he really was awesome on providing me this bikeand Florian Lamana for the fast service. Also thanks a lot to all the guys at Tartybikes who really helped me on my questions concerning the rear wheelbuild. That bike is really awesome and so easy to build. It is clearly the most rigid and efficient bike I have ever ridden! I am so happy as it has been 3 months since I wanted one.
Specs:
Frame and Fork
- Frame: Crewkerz Cleep 2
- Fork: Try-All Karbons, 4-Bolt mount. 1"1/8 steerer tube with Hope 1,5" Headset reducer
Wheels
- Front hub: Breath sealed bearing, 28h with titanium bolts
- Rear hub: Hope Pro 2 Evo 40T Trials, 12mm bolt through axle, splined cassette, Hope spacers
- Chain tensioner: Crewkerz WAW (Wild And Wired)
- Front rim: Maestro, 28h, single wall, 32mm wide
- Rear rim: Trialtech SL (with parallel sidewalls), 32h, single wall, 47mm wide
- Spokes: Sapim Race, silver
- Nipples: Aluminium, silver
- Rim tape: Custom
- Inner tube (front): Decathlon
- Inner tube (rear): Decathlon
- Front tyre: Vee Tire Co, The National - WaW Edition, 26" x 2.0"
- Rear tyre: Vee Tire Co, Trax AM - WaW Edition, 26" x 2.5"
Brakes
- Front brake: Magura HS33 2005 with Racing Line Aluminium piston
- Rear brake: Magura HS33 2005 with Racing Line Aluminium piston
- Brake clamps: Try-All CNC with titanium bolts
- Brake Pads: Coust Pads, 8mm version
Drivetrain
- Cranks: Crewkerz WAW, 165mm, with integrated axle and splined system freewheel and Trialtech singlespeed kit (spacers)
- Front Sprocket : Trialtech 18t
- Chain: KMC Z610HX 3/32", silver
- Rear Sprocket: Trialtech Splined, 15t
- Pedals: Echo SL Titanium Caged
- Bottom bracket: AS30 with aluminium axle, unique to Crewkerz, offering larger bearings and a stiffer interface
- Bashring: Crewkerz WAW
Steering
- Headset: FSA/Monty Internal upper Half and Hope 1,5" Internal lower half
- Stem: Rockman/Try-All Forged 150mm x 30°
- Grips: WIlson Tennis Grip
- Handlebars: Try-All Carbon riser cut to 680 mm
Geometry
- Wheelbase: 1090mm
- Chainstay: 380mm
- BB Height: +65mm
- Head Angle: 72°
- Reach (from centre of BB shell to top centre of head tube): 670mm
Edited by Canardweb
