Cooper01t Posted October 6, 2015 Report Share Posted October 6, 2015 (edited) I just wondered if any one could help me recently I got my magura hs33 brakes Bled by a shop and they told me that the brake still isn't working very well , brilliant, you have to pull the brake in pretty hard to get any sort of grip but I don't trust it at all what could I do to make it hold the wheel better and actually lock the wheel without pulling the lever in so hardany sort of input will be appreciated Edited October 6, 2015 by Cooper01t Quote Link to comment Share on other sites More sharing options...
kaarel Posted October 6, 2015 Report Share Posted October 6, 2015 You must give more information.. What pads, rim, grind/no-grind etc.. If you pull the leaver and brakes don't start moving right away then the bike shop made some bad bleeding... Quote Link to comment Share on other sites More sharing options...
Cooper01t Posted October 6, 2015 Author Report Share Posted October 6, 2015 Onza rim no grind think the pads are standard hs33's and as far as I know they do start moving straight away Quote Link to comment Share on other sites More sharing options...
isitafox Posted October 6, 2015 Report Share Posted October 6, 2015 There's your problem. Ditch the standard pads for something like some Trialtechs or Heatsink yellows and if it still isn't good enough then give the rim a grind Quote Link to comment Share on other sites More sharing options...
kaarel Posted October 6, 2015 Report Share Posted October 6, 2015 Also, there is the quick semi-fix to use tar with Magura pad's but for your own safety, get some proper pads! Quote Link to comment Share on other sites More sharing options...
Cooper01t Posted October 6, 2015 Author Report Share Posted October 6, 2015 Thanks a lot so would this stop me having to pull the lever almost completely in for the wheel to lock? Quote Link to comment Share on other sites More sharing options...
kaarel Posted October 6, 2015 Report Share Posted October 6, 2015 On 10/6/2015 at 1:24 PM, Cooper01t said: Thanks a lot so would this stop me having to pull the lever almost completely in for the wheel to lock?This depends on the setup. If your current brake pads are used and gotten thin then yes, new pads with new setup will stop that problem.You could fix it right now by screwing the TPA in from the leaver (the red thingy on leaver blade). Quote Link to comment Share on other sites More sharing options...
ooo Posted October 6, 2015 Report Share Posted October 6, 2015 What is the problem is it that it is spongy or it doesn't hold ? To elaborate:If you go out riding and when you press the lever it is hard but the wheel slips, it is a pad/rim problem. You'll need a grind, and if you have been riding in the rain you need pads that work well when wet.If the lever is spongy and goes all the way in even though the pads made contact it is a bleed problem. Maguras are pretty hard when bled properly (minus the flex in the frame).The other issue is your pads may be setup too far away from the rim and are barely making contact, so move them closer, they should be about the thickness of a 1p coin away. If you wheel is bent this will be hard to do. Get a spoke key.Look for leaks, and check where tpa is, it should have been wound all the way out for bleeding. Take some pics of the setup if you still have trouble. Quote Link to comment Share on other sites More sharing options...
Cooper01t Posted October 6, 2015 Author Report Share Posted October 6, 2015 They're making contact but the lever is spongy the bloke in the shop did say to me that because the brakes had been bled with water (previous owner) the seals had been damaged Which is causing the brake to not function properly I actually didn't believe him at the time because all he kept saying about was putting a whole new hs33 on the bike so just thought he wanted the money for the new brake to be honest Quote Link to comment Share on other sites More sharing options...
JJ Leigh Posted October 6, 2015 Report Share Posted October 6, 2015 (edited) probably tpa is knackered of there is dust, a kink maybe? (or something) blocking the oil flow. do you pull the lever in and it comes very close to the handlebars? also ignore anyone whos blabering on about rims and pads, its the mechanism of the brake you wanna sort out first However, if there is virtually no pad left or you're Slave is far away from the rim then it obviously wont bite or hold but thats common sense. Edited October 6, 2015 by JJ Leigh Quote Link to comment Share on other sites More sharing options...
Cooper01t Posted October 6, 2015 Author Report Share Posted October 6, 2015 There is a lot of pad left I did check that how would I go about checking the tpa to see if it's functioning properly? Quote Link to comment Share on other sites More sharing options...
kaarel Posted October 6, 2015 Report Share Posted October 6, 2015 On 10/6/2015 at 1:47 PM, Cooper01t said: They're making contact but the lever is spongy the bloke in the shop did say to me that because the brakes had been bled with water (previous owner) the seals had been damaged Which is causing the brake to not function properly I actually didn't believe him at the time because all he kept saying about was putting a whole new hs33 on the bike so just thought he wanted the money for the new brake to be honestAnd you found the other problem besides the pads. If the brake was water bled before and wasn't serviced properly then the easiest way is to just get a proper, working brake.. Quote Link to comment Share on other sites More sharing options...
isitafox Posted October 6, 2015 Report Share Posted October 6, 2015 On 10/6/2015 at 1:47 PM, Cooper01t said: They're making contact but the lever is spongy the bloke in the shop did say to me that because the brakes had been bled with water (previous owner) the seals had been damaged Which is causing the brake to not function properly I actually didn't believe him at the time because all he kept saying about was putting a whole new hs33 on the bike so just thought he wanted the money for the new brake to be honestThis sounds like part of the problem also, bleeding with water won't affect the seals like that. It'll probably need bleeding properly, maguras seem to be a bit of a minefield when it comes to regular bike shops nowadays as most don't ever seem to deal with them (my cousin has a drawer full of magura fittings and spares he said I'm welcome to anytime as he literally never ises them) but then I'd still get some new pads to compliment it. If you look on YouTube there's a guide to water bleeding brakes somewhere (anyone care to link as I'm on my phone?) or I'm sure Tarty bikes have a guide on their site. Quote Link to comment Share on other sites More sharing options...
ooo Posted October 6, 2015 Report Share Posted October 6, 2015 (edited) On 10/6/2015 at 1:54 PM, Cooper01t said: There is a lot of pad left I did check that how would I go about checking the tpa to see if it's functioning properly? just turn it and watch the pads they should move in and out a tiny bit, also squeezing the lever after adjusting it see if it feels different. Sometimes tpas just get stuck and don't turn at all.the tpa just adjusts the pads position, you can just move the slaves in the clamps too. so if it is spongy, its not just the tpas fault.maybe try a water bleed? Edited October 6, 2015 by ooo Quote Link to comment Share on other sites More sharing options...
Cooper01t Posted October 6, 2015 Author Report Share Posted October 6, 2015 Thanks for all the input from everyone I'll have a look when I get home from work and see what I can do Quote Link to comment Share on other sites More sharing options...
