jnthebiker Posted August 8, 2015 Report Share Posted August 8, 2015 Hey. I'm running koxx yellow pads(the ones that came on kloud complete bikes), with an echo tr 26" rear rim. I've got a dead grind and my brake slips a lot. How harsh of a grind should I do for these pads? Thanks, JN Quote Link to comment Share on other sites More sharing options...
jeff costello Posted August 8, 2015 Report Share Posted August 8, 2015 about 3.64 2 Quote Link to comment Share on other sites More sharing options...
jnthebiker Posted August 8, 2015 Author Report Share Posted August 8, 2015 about 3.64 What? 3.64? Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 8, 2015 Report Share Posted August 8, 2015 Doesn't need to be particularly harsh. Don't keep going over the same spot with the grinder because if you do it'll dull the grind, so you could make it as harsh and you want and it won't bite/hold any better. Quote Link to comment Share on other sites More sharing options...
jnthebiker Posted August 8, 2015 Author Report Share Posted August 8, 2015 Doesn't need to be particularly harsh. Don't keep going over the same spot with the grinder because if you do it'll dull the grind, so you could make it as harsh and you want and it won't bite/hold any better. ok, thanks! Quote Link to comment Share on other sites More sharing options...
N.Wood Posted August 10, 2015 Report Share Posted August 10, 2015 Oddly I found my old Koxx Yellows to be useless, which is a bit odd as Koxx Browns and Koxx Reds were awesome. I gave up on my yellows and used the old 25mm coust pads, could never get them to work. Quote Link to comment Share on other sites More sharing options...
weebryan Posted August 10, 2015 Report Share Posted August 10, 2015 I found the old koxx yellow worked better in the wet/rain, Browns were overall and red dry dusty conditions Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted August 10, 2015 Report Share Posted August 10, 2015 Light grind if you want best dry weather performance IMO. Quote Link to comment Share on other sites More sharing options...
littlekarlypilkboid Posted August 10, 2015 Report Share Posted August 10, 2015 for best results do roughly 15mm deep Quote Link to comment Share on other sites More sharing options...
Mark W Posted August 10, 2015 Report Share Posted August 10, 2015 Oddly I found my old Koxx Yellows to be useless, which is a bit odd as Koxx Browns and Koxx Reds were awesome. I was all about the Greens - those pads were the shit. Quote Link to comment Share on other sites More sharing options...
jnthebiker Posted August 11, 2015 Author Report Share Posted August 11, 2015 Thanks guys. I did a light grind, and haven't ridden with it yet, but riding around in the house to test them they seem AMAZING! Quote Link to comment Share on other sites More sharing options...
