gloves/grips
AWT
hi guys, my hands are f**ked now from my bad skin, to the point of bleeding on rides, so im going to have to try out some gloves.
what are people using atm? way back i used to use raji's?? by 661 ?
thinking trial tech foams with some nice gloves ?
thanks
Are your hands dying on rubber or foam?
If it's rubber and you're not too keen on gloves, try foam. They're weird to get used used to, but great once you've adjusted, and much less harsh on the skin.
If it's on foam/both then I can't help you. I'd rather just continue bleeding than ride in gloves :P
  • Like 1
Have you considered hand maintenance? Moisturise and cut back the thicker skin so it doesn't crack, use a pumice stone to grind the skin back until you have a callous pad left that isn't so thick it can't move so tears the skin around it.
I've found that it's far better to have a thin flexible pad than thick hard skin, it takes a bit of practise to get the right thickness as too thin you can tear the callous right off.
Ha
of course, ive lived with this for as long as i can remember, always had it..
been docs allot of times, and finally found a cream that seems to be doing the job, but all it takes is washing my hands with cheap soap/washing up liquid and they start to crack again, then if i go riding it just gets worse.
gone with neon foams and the jitsie gloves for when they are start to hurt :) its also not the callous thats the problem
this pic is 4 days no riding and the best they have been in a good few weeeks
11822753_839884982774750_141793944098186
Edited by AWT
Ah so it's your palms that are cracking not calluses :)
Is it an eczema or just very dry skin? Have you tried homeopathic remedies rather than medicinal ones? Look at essential oils that can be used to moisturise the skin.
I suffer from dry skin on my hands and get cracking between my fingers (nothing as bad as yours) and neutrogena norwegian formula cream is generally sufficient to recover them; however if they're bad enough to crack it normally takes 2-3 days of regular application.
edit: my stepson suffers from eczema and cannot use most soaps without a massive flair up. Any regular shampoo or bubble bath will cause him agony for 3 weeks. We use soaps/shampoos from faith in nature and they're very good, no sls or parabens and don't flair up Reuben's skin :)
Edited by forteh
  • Like 1
its a strange one because my right hand is near enough fine but the left.. if i use say carex soap and dont put cream on after they just dry up within hours, its hard to always cream up though as it gets on everything as im sure you're aware :(
ill look up the shower gel shampoo :)
another bad one is lynx shower gel that destroys them
for anyone thats cares to the neon grips feel excellent and are what ill be sticking with :)
What's the cream that you find effective? Is it a steroid or moisturiser? We have had very good results with calendula cream with Reubens skin, not hard to decant some into a small tube or tub. The wife also says to look into bria organics relief, repair, replenish skin cream :)
Sounds as though you just have an eczema on the one hand. We use the faith in nature seaweed soap and Reuben doesn't react to it, the same with Dr organics lavender stuff.
If its cream your after i use 'Hemp Hand Protector' from the body shop and it is ace! Use it every day you're not planning on riding as it makes your hands pretty greasy and if you try and remedy hurting hands on a ride with it not much happens, but on the days in between it makes them feel much better when you come to ride!
  • Like 1
