ogre Posted July 3, 2015 Report Share Posted July 3, 2015 hey everyone, i have an echo lite and i use rockman hubs; i currently have a pair of snail cams in my frame to space them out. would the 5mm spacers mean that i don't need any cams at all (if i remove my current spacers/cams) or do i need to carry on using my spacers and some of the other ones please? on a side note, because the tarts will read this... A guide to specify the spacing and what cams usually measure in at would be super useful Quote Link to comment Share on other sites More sharing options...
niconj Posted July 3, 2015 Report Share Posted July 3, 2015 Aren't all snail cams 3mm wide? Quote Link to comment Share on other sites More sharing options...
Mark W Posted July 3, 2015 Report Share Posted July 3, 2015 They should be, yeah - they're all made to be 3mm, so they'd be around that kind of figure. If you're wanting to get a fast answer, the easiest way would just be to measure the rear end spacing of your frame, then measure up your hub with the different spacers on there and see what works out best. Most trials company measurements are fairly freestyle so it's the best way to ensure you'll definitely get this right Quote Link to comment Share on other sites More sharing options...
AdamR28 Posted July 4, 2015 Report Share Posted July 4, 2015 measure the rear end spacing of your frame, then measure up your hub with the different spacers on there and see what works out best. Most trials company measurements are fairly freestyle so it's the best way to ensure you'll definitely get this right This. Quote Link to comment Share on other sites More sharing options...
