waybe2014 Posted July 3, 2015 Report Share Posted July 3, 2015 Are there any mod frames that use a 20" rear wheel and have disc mounts, or would a 20 rear fit in a frame designed for a 19 rear? Quote Link to comment Share on other sites More sharing options...
isitafox Posted July 3, 2015 Report Share Posted July 3, 2015 I don't think there are any standard 20" rear frames with a disc mount, most tend to use V brakes but a 20" will fit in a normal mod frame if you run a rear disc as the actual wheel size including tyre is the same. Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted July 3, 2015 Report Share Posted July 3, 2015 Roulon. They were a small batch production of (russian?) TF specials where the 4bolt mounts were wrong and needed a 20in wheel to run rim brake, and to run a 19 you needed to run disc. I guess that would qualify? Quote Link to comment Share on other sites More sharing options...
