headset wobble
jeff costello
i've been slowly trying to-fronts (very timidly, just on flat earth) and now i've noticed that the headset has developed some play under force. when i hit the front brake and heavily lean on the bars, i can sense it move quite a bit.
i've took it apart and everything seems to run smooth and sit tight. the headnut is as tight as i can do by hand (with a pretty big allen wrench). the forks are echo urban and the headset is some kind of echo too (TR, i think).
is that normal with trial bikes or is my headset damaged? if i keep riding like this will it possibly damage my headtube? or can i just keep riding it until the headset falls properly apart?
thanks.
Sounds like the steerer tube has bent or the headtube had flared.
Is the movement fore and aft relative to the frame? Try turning the front wheel through 90° and see if you can get the headset to clunk/move, if it does I would suspect the headtube. If it only moves in the direction of the wheel then I would suspect the steerer tube, however aluminum steerers will tend to simply snap than bend.
If the headtube is flared there isn't much you can do about it unfortunately, you might be able to get a bit of steel shim to sit in there but it's never going to be a good solution and very difficult to get straight in there.
i think i solved it! luckily it was none of that.
thanks! this helped me find the culprit! turning the wheel around, i could more clearly see it moving. it was definitely the steerer shaft moving around.
the mysterious problem was: i had been using a hope spacer set and (i think) it sits wrongly on the top part of the echo headset. with the wrong spacer i could not get enough tension from the headnut. i added the original echo-spacer at the bottom and the wobble's now gone. the echo spacer is visibly thinner than the hope ones.
Edited by jeff costello
  • Like 1
that was my first guess as well. but i checked and i had appr. 3mm of space between top of steerer and top of stem.
my explanation is this: the top washer of the echo headset has a bit of a groove and the echo spacer fits right in there. while the fatter hope one just sits on top. no idea whether this is really true though.
you can see the groove a little bit in this pic (the silver one on the left):
  • 2 weeks later...
i think the problem's still there. probably the spacer wasn't it after all.
quick question for elimination:
with headsets (echo in my case) are the top and bottom bearing identical? - in other words: do i have to check whether they are mounted in the correct position?
while trying to leverage the thing out with a screwdriver (upper cup stuck in there pretty good) the thing came out in pieces: first the inner ring, then the rest. even a ball popped out. if it were really necessary, put back together i think it would work for a few more day.
but i had the ritchey bearings around and they fit. didn't use the ritchey cups, top plastic race and cover though, because they are superugly. seems to work fine for now. taking it for a test ride tomorrow morning.
i've been using it for about a year and a half, usually for an hour a day. so maybe it might be old age? beginner stuff only though, no to-fronts or hooks or any of that.
also i've moved the headset from my inspired to my new mod last christmas (i normally leave headsets in place, but funds were small), maybe i did some damage then.
at least the new one doesn't move, even if i lean on it my heaviest. even with the botch job i could clearly see the steerer move in the hole of the top bearing. but i'll see for real when i take it for a ride tomorrow morning.
The steerer is usually going to have a bit of movement around the centre of the bearing races, that's why they've got the tapered washers/races to sit in them so you can get the tension adjusted properly. When the headset is properly fitted you shouldn't be able to see the bearings at all, really.
no no no, of course i couldn't see the bearing. there's the top cap in the way. i added this only to properly describe where i saw it moving.
since i've now exchanged every party involved apart from the frame, i hope i'm fine now. thanks for your constant effort and good advice (and everyone else's of course).
ugly, but it works. no wobble after the first ride. so success, i hope.
maybe the bottom cup of the echo headset was the real culprit. the bearing always immediately slid out of it when i took the think apart.
general last question about trials and headsets: do headsets get loose after a while of trials use and need re-tensioning? or do you just set it up once and it's set forever?
Quite often need to be re-tensioned on the first ride once everything beds in, but then should be pretty much set after that. Certain headsets (like Kings) tend to need a bit more retensioning but the Echos are pretty much done after the first ride.
That shouldn't really be an issue - the only part of the cup that plays any important role in how tight your headset is is the angled part of it. If you look at the new Trialtech Sport Lite headset it's pretty much just the angled shoulder of the cup and that's it, which should give you an idea of how much of a role it plays. Once everything's done up tight it should be good to go.
I seem to remember I had to open up the slot in the top race of one of my Echo headsets for it to work properly, but I can't really remember why that was/what the issue had been.
