probably very stupid bash ring question
jeff costello
hi,
could i take a standard bash ring for a ffw crank and mount it on the bottom bracket instead?
like one of those
aren't freewheels and bottom brackets both bsa and hence the same size of thread? this would mean the bash would fit between bb cup and frame too?
(i know the chainline will shift a bit, but i'm not too concerned with that)
background:
i use a bmx crank in the front. i have 25t sprocket with a bash on right now, but i might want to go down to an 18t sprocket. i do have the sprocket, but there isn't a bashring for that size available anywhere. running the chain without a bash freaks me out.
if someone could measure the inside diameter of one of those bashs, that would be very helpful as well. thanks.
