Magura problem
seaine
Hi,I was out riding today and the lever just pulled right back to the bar.i don't know if it could be the tpa stripped or a sticky piston.the brake still bites when the lever is pulled to the bar .
Any ideas?
ummm and there isn't any seals gone within the brake lever itself or the piston seals ! Wont of thought the tpa would have any affect on the brake performance as it has no seals for fluid to escape from. if it were me id remove the brake and test for leaks in water as oil will float apart from that im stumped !!!!
