Guillermo Marin Posted April 24, 2015 Report Share Posted April 24, 2015 Hey, I have a Monty pro race rear tyre, that is out of the rim when i'm riding...now that's working good for a week because i added glue(as you can see in the pic) but i guess it will not work after a wheel puncture. It's almost new and i dont want to buy a new one. Any advice? Thanks.subirimagenes Quote Link to comment Share on other sites More sharing options...
CC12345678910 Posted April 30, 2015 Report Share Posted April 30, 2015 (edited) I know of a roadie bike 'get you home' where you use several sections of duct tape wrapped around a deformed or ripped tyre bead along the length (running left to right on your photo) of the problem area. The idea being that it builds up the bead thickness and the tyre then grabs like usual. That might work?? Can't say I've ever used this idea though... Maybe simple push down on that part of the bead from flat and inflate as usual, that's never failed for me with any sketchy 2nd/3rd/millionth hand tyres I've used. Maybe do it using a compressor so this is not a two person job? Edited April 30, 2015 by CC12345678910 1 Quote Link to comment Share on other sites More sharing options...
ogre Posted April 30, 2015 Report Share Posted April 30, 2015 Have you tried the same tire on a different rim? The bead could have failed under your sheer henchness 2 Quote Link to comment Share on other sites More sharing options...
Guillermo Marin Posted April 30, 2015 Author Report Share Posted April 30, 2015 Have you tried the same tire on a different rim? The bead could have failed under your sheer henchness I dont have another rim. I've rotated the tyre and i also have changed the air tube. I'm sure it's a tyre problem Quote Link to comment Share on other sites More sharing options...
