isitafox Posted April 12, 2015 Report Share Posted April 12, 2015 I know how to figure out the correct chain length when running more than one chainring but is there a specific method for measuring it with a single ring setup? Quote Link to comment Share on other sites More sharing options...
monkeyseemonkeydo Posted April 12, 2015 Report Share Posted April 12, 2015 Should be basically the same. I stick the bike in the lowest gear and then set the length so the mech is being pulled up towards the frame a reasonable but not excessive amount. One thing to remember if you're doing it on a full sus bike (which I only learned the hard way when going to 1x10) is to let the air out of the shock and fully compress the suspension to ensure you cover the 'worst case'. 2 Quote Link to comment Share on other sites More sharing options...
